Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Simulating Fire on Transient Thermal Analysis › Reply To: Simulating Fire on Transient Thermal Analysis
April 5, 2024 at 7:57 pm
mjmiddle
Since it says the temperature in the fire curve is the fire temperature, you should be able to specify it in a convection boundary condition in tabular data with multiple time points.
I'm not sure what you would use for the convection coefficient, if you want to stick with a constant or if you also have some testing data for that.
If you need a very accurate analysis, you should be using a fluid solver.
