Ansys Learning Forum › Forums › Discuss Simulation › Electronics › High voltage cable in Maxwell 3D › Reply To: High voltage cable in Maxwell 3D
GLUO
Yes, Icepak model has to be in 3D. Please select the two ends of the conductor, assign current to both of them, one goes inside the region and the other goes outside of the region. You can use the default boundary (no additional boundary needed).
GL
