Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS Dyna full deck restart › Reply To: LS Dyna full deck restart
Hello Ajay,
Do you have the original input file (first_Impact.k) and the restart file (2nd impact; restart.k) in the same folder? You should have results of the first impact (include dynamic relaxation state at time=0) in the d3plot. When you restart, LS-DYNA will continue the d3plot file series as d3plotaa and keep adding results. It should look like this:
So, when you open the d3plot file, you will get results from the first and second impacts.
I recommend doing some tests with a simple cube model. This way you will be able to run quickly and make changes as needed.
Here is the full restart procedure from our knowledge database:
"Changes of a general nature can be made in a full restart, including addition of parts, loads, and contacts.
Sample execution line
SMP: lsdyna i=fulldeck.k r=d3dump01
MPP: lsdyna i=fulldeck.k n=d3full01
where fulldeck.k is a complete keyword input deck for the model you want to use moving forward in time.
Copyright © 2003-2012 by LIVERMORE SOFTWARE TECHNOLOGY CORPORATION
Full Restart (cont’d)
Guidelines for fulldeck.k
Include keyword input for anything that is to be retained from the original run… (*PART, *SECTION, *MAT, *CONTACT, *LOAD, etc.). Normally, you would just copy the original input deck and strip out anything you don’t want to retain.
Also include keyword input for new parts, materials, contacts, loads, etc.
Include all relevant *DATABASE and *CONTROL commands.
Include the command *STRESS_INITIALIZATION.
Signals to LS-DYNA this is a full retart and that stress, strain, displacement, etc. are to be initialized for specified, pre-existing parts.
Do not use *INITIAL_VELOCITY for nodes carried over from previous run. Use *CHANGE_VELOCITY_option to modify velocities of such nodes.
Preexisting contacts that are to be retained should include the _ID option so that the contact ID numbers in the original input deck match those in the full restart input deck.
Regarding output from a full restart:
Binary output (d3plot) from a full restart will blend seamlessly with previous output.
ASCII output (glstat, matsum, etc.) from a full restart appends to pre-existing ASCII output only if *CONTROL_OUTPUT with IASCII=1 in included in the full restart deck.
Without this command, ASCII output from full restart overwrites pre-existing ASCII output.
Lastly, there may be a suitable alternative to using a full restart.
For example, a “dynain” file can be written at the conclusion of the original run by including the command *INTERFACE_SPRINGBACK_LSDYNA in the original input deck. This dynain file can be included in a subsequent keyword input deck to initialize nodal coordinates and element history variables (stress, strain, etc). "
https://ftp.lstc.com/anonymous/outgoing/support/FAQ_docs/restart.pdf
https://ftp.lstc.com/anonymous/outgoing/support/FAQ/restart
Let me know how it goes.
Reno.
