Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Negative force in the translational motion of the BLDC motor › Reply To: Negative force in the translational motion of the BLDC motor
April 5, 2024 at 4:40 pm
GLUO
Since you are using a constant speed, please make sure the initial position and the current phase is aligned to provide a positive torque. Please also check the if magnet magnetization direction is correct.Â
GL
