Ansys Learning Forum Forums Discuss Simulation Fluids Why is there no Burnout Stoichiometric Ratio? Reply To: Why is there no Burnout Stoichiometric Ratio?
SVV
Hi ,
The Burnout Stoichiometric Ratio and Heat of Reaction for Burnout are no longer available in the Create/Edit Materials dialog box, as these parameters are now computed from the particle surface reactions you defined in the Reactions dialog box. For more information refer to 20.7.2. Setting Discrete-Phase Physical Properties (ansys.com)
