Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Input periodic boundary conditions in a unit cell › Reply To: Input periodic boundary conditions in a unit cell
isabel.prestes
Hi mjmiddle,
Thanks, it seems indeed that this should solve my problem.
The unit cells should be touching each other, so the distance between them should be zero. However, I cannot set it as zero in the linear shift. Or should I give the height of my structure as the shift?
