Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Fluent Calm Water Conditions for decay test › Reply To: Fluent Calm Water Conditions for decay test
Murtala Musa
Thanks for the response Rob,
1) In the case I use open channel flow as you suggested, the velocity magnitude at the inlet should be zero right?
2) How can I, then, create a report definition that plots roll and heave decay with time, Just as in the heave decay image below?
     My simulation is on a Spar cylinder hull seen in the image below, any suggestion will be appreciated. thanks!
HEAVE DECAY Model setup
