Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › resolution method used for the Fluid calculation › Reply To: resolution method used for the Fluid calculation
Devendra Badgujar
Resolution in Discovery do you mean Fidelity of the solution? The fidelity of the solution is controlled primarily using the slider in the stage navigator.
This acts differently depending on if you are in Explore or Refine stage. In both cases an increased fidelity will capture additional detail but will take longer to produce a result.  Optimizing Performance with Solution Fidelity (ansys.com)
For Fluid flow, we can use Curvature and Proximity Size Function from Global fidelity settings which controls how the mesh size is distributed on a surface or within a volume. For more information, you can refer Curvature and Proximity Size Function (ansys.com)
Devendra
