Ansys Learning Forum Forums Projects & Partners Kampus Merdeka Problem with modal analysis in ansys workbench Reply To: Problem with modal analysis in ansys workbench
Aniket Chavan
Please check:
/courses/index.php/courses/modal-analysis-in-ansys-mechanical/
/courses/index.php/courses/cantilever-beam-modal-analysis/
It's also important to note that the deformation values obtained from a modal analysis are not scaled to any particular force level; they are normalized and typically used to understand the deformation patterns. If you are looking to obtain deformation values under specific loading conditions, you might need to perform a static structural analysis or a prestressed modal analysis where the effects of certain loads are considered.
-Aniket
Forum Rules & Guidelines
