Ansys Learning Forum › Forums › Discuss Simulation › Fluids › coupled simulation of vehicle and fluid tank › Reply To: coupled simulation of vehicle and fluid tank
vikram chahal
could you please provide the UDF code. i have write this one
#include "udf.h"
DEFINE_SOURCE(moment_source, c, t, dS, eqn)
    real time = CURRENT_TIME; // Get the current simulation time
    real moment = 0.0; // Initialize moment to zero
    real CG[ND_ND]; // Center of gravity coordinates
    real cellCG[ND_ND]; // Cell center coordinates
    C_CENTROID(CG, c, t); // Get CG of the domain
    C_CENTROID(cellCG, c, t); // Get cell center coordinates
    real distance_from_CG = cellCG[2] - CG[2]; // Distance along z-axis
    /* Check if time is within the specified duration */
    if (time <= 2.0)
        /* Apply moment only to cells at CG */
        if (distance_from_CG = 0.0)
            moment = 5000.0; // Apply 5000 Nm moment
    dS[eqn] = 0.0; // Reset the source term
    return moment; // Return the moment as the source term
and hooked as the souce term of fluid domain under cell conditions.
