Ansys Learning Forum Forums Discuss Simulation Fluids CFX vs. Fluent – significantly different results with the same settings, bc Reply To: CFX vs. Fluent – significantly different results with the same settings, bc
CAP_NJ
Hi CFD_Friend,
thanks a lot for your answer!!! I tried a lot a of ways to calculate the force (even the way you mentioned). In the end the problem was, that I have had set the option "include reference pressure" to "t" (true?) in CFX. In my understandng I would expect the force would be defined as shown on the figure above, just like in fluent, but it was different. I still had to define the relative pressure (pt_inlet-p_ref) at the inlet and outlet (p_outlet-p_ref). It does not make sense to me, but it works like that.
Thanks again and best regards!
