Ansys Learning Forum Forums Discuss Simulation Fluids Pressure Outlet Definition for Accurate Sloshing Simulation Reply To: Pressure Outlet Definition for Accurate Sloshing Simulation
Prashanth
Hello, I don't understand. If your sloshing model does not have a pressure boundary, you need not use it or vice versa. You can have a closed domain if you want, move the cell zone, and still simulate sloshing. Compressible liquid equations like Tait's is not needed, unless the pressures are high as such, like hydraulics etc..
