Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › large deflection on beam › Reply To: large deflection on beam
April 5, 2024 at 4:31 am
Akshay Maniyar
Keep large deflection ON as it will consider the stiffness change due to shape. What is the material of the beam? Make sure that the command snippet that you are using for material and Mechanical units is correct.Â
Thanks,
Akshay Maniyar
