Ansys Learning Forum › Forums › Discuss Simulation › Photonics › app is crashing › Reply To: app is crashing
April 4, 2024 at 6:22 pm
Hi Ashish,
I used your code with cen_w = 1280 nm and w_span = 0 nm (not sure what you used for this field), I do not see any issue with the created dipole source. Here's a screenshot of the Frequency/Wavelength tab of the Dipole Source:
Would you be able to share a screenshot of yours?
I also ran the simulation (just a dipole in air) and checked the monitor results, in the results, the wavelength is also 1280 nm as you can see below:
You can find sample optimzation script here: Creating optimization tasks using a script
Amrita
