Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Regarding phase-delay spectrum of metasurfaces › Reply To: Regarding phase-delay spectrum of metasurfaces
April 4, 2024 at 6:16 pm
Hi Nasem,
Thanks for sharing the screenshot! I believe they are using a wider range of wavelength than you are, is that correct? Secondly, for their figure the x-axis is radius and the y-axis is wavelength. For yours, it's the opposite. Are you intentionally running the simulation for a shorter wavelength range? Also, would you be able to reverse the axes and share a screenshot?
Amrita
