Ansys Learning Forum › Forums › Discuss Simulation › Electronics › De-embedding port in Ansys Circuit › Reply To: De-embedding port in Ansys Circuit
David Prestaux
Hello Rafik, you may also use HFSS port solver as a transmission line model and used it in cicuit. once done, you will be able to assign the length as a parameter.
1/ include a HFSS design as port based solution / transmssion line model:
use HFSS port solution  as transmission line model
2/ parameterize the transmssion line model:
