Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Hydroelastic simulation using Ansys AQWA › Reply To: Hydroelastic simulation using Ansys AQWA
S.S.S.ShankaVasuki
Hi Ingrid,
Thank you for your quick response. Bascially, my end goal is to get the RAO of my flexible cuboid when its placed on water. I did think about the second option you mentioned which is to break my cuboid into smaller chunks and then interconnect them via connections by specifying the stiffness and the damping coefficients. But, in this case, I was wondering if I could estimate the individual responses of each of the chunks? or does it give the response of the entire structure? Please let me know.
Thank you!
