Ansys Learning Forum Forums Installation and Licensing Ansys Products Hydroelastic simulation using Ansys AQWA Reply To: Hydroelastic simulation using Ansys AQWA
Ingrid M
it depends on what your end goal application is but you could also look into coupling Aqwa with Rigid Body Dynamic application if this is relevant to you.
Alternatively, you can break down your cube into smaller shunks which are linked with connections where you can specify  its stiffness and damping coefficients.
I hope this helps,
Ingrid
