Ansys Learning Forum Forums Discuss Simulation Electronics Finite Array Simulation in HFSS Reply To: Finite Array Simulation in HFSS
dushyant.marathe
Hi Aman,
Thanks for posting your queries on learning forum.
You can use a plane wave exciatation source to model a incident wave. This should provide you a directivity.
Regarding your second question, modelling the unit cells of array with varying RLC parameters for each, you may raise a service request to Ansys Technical Support and support engineer will get in touch with you to answer your query.
Thanks,
