Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Creation of a MATRIX27 element, but no effect on the result › Reply To: Creation of a MATRIX27 element, but no effect on the result
Hi Dave,
Thanks for your reply. COMBI214 is unfortunately not enough to model the bearing, because it needs 4X4 unsymmetrical stiffness and damping matrices with negative values for the bearing in UX, UY, ROTX, ROTY directions. I just figured out why the snippet I posted above didn't work as I wanted, because I was attaching the MATRIX27 elements with pilot nodes that are fixed. I modified my mesh and created some nodes as fixed to the ground and attached the MATRIX27 elements to these nodes instead of the pilot nodes. After that it works fine. But now I have another question. While I was entering unsymmetrical stiffness and damping matrix with negative values using MATRIX27, ANSYS reminded me:
"For element type= (MATRIX27),KEYOPT(1) cannot be 1 when KEYOPT(2) is greater than zero."
Does this mean that I cannot enter a negative definite matrix if I set KEYOPT(2) = 1 (unsymmetric matrix)? For example, one of the stiffness matrices looks like this:
