Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to export the results when maximum stress occurs › Reply To: How to export the results when maximum stress occurs
Akshay Maniyar
Hi Bob,
You can export results for a particular time with the same option 'Export < Export text file', but before that, you have to evaluate the result for the time for which you want to export the results. First, right-click on the graph with the maximum value and evaluate the result for that time and then export the text file.
Thanks,
Akshay Maniyar
