Ansys Learning Forum Forums Discuss Simulation Fluids Error in DEFINE_PB_BREAK_UP_RATE_FREQ UDF example from manual Reply To: Error in DEFINE_PB_BREAK_UP_RATE_FREQ UDF example from manual
SRP
The error you're encountering (SIGSEGV) typically indicates a segmentation fault, which commonly occurs due to accessing memory that you don't have permission to access.
To debug Print out the values of epsi, alpha, and rho_d before using them in calculations to ensure they are not causing any issues.
