Ansys Learning Forum Forums Discuss Simulation LS Dyna LS Dyna – can’t reach license server Reply To: LS Dyna – can’t reach license server
1617836513
 ___________________________________________________
     |  Livermore  Software  Technology  Corporation   |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Version : smp s R8.1.0    Date: 02/24/2016     |
     |  Revision: 105896          Time: 14:28:04       |
     |  Features enabled in this version:              |
     |    Shared Memory Parallel                       |
     |    FFTW (multi-dimensional FFTW Library)        |
     |    Interactive Graphics                         |
     |    ANSYS Database format                        |
     |    ANSYS License (ANSYS145)                     |
     |  Licensed to:                                   |
     |  Platform   : WINDOWS X64                       |
     |  OS Level   : Windows 7/8/10 & Server 2008/2010 |
     |  Compiler   : Intel Fortran XE 2013 MSVC++ 2010 |
     |  Hostname   : xianxianxian                      |
     |  Precision  : Single precision (I4R4)           |
     |  SVN Version: 105897                            |
     |  Unauthorized use infringes LSTC copyrights     |
 Executing with ANSYS license
 Input file: d:\penetr~1\budong.k
 The native file format       : 32-bit small endian
 Memory size from default     :    20000000
 on UNIX computers note the following change:
 ctrl-c interrupts ls-dyna and prompts for a sense  switch.
 type the desired sense switch: sw1., sw2., etc. to continue
 the execution.  ls-dyna will respond as explained in the users manual
    type                      response
   quit    ls-dyna terminates.
   stop    ls-dyna terminates.
   sw1.    a restart file is written and ls-dyna terminates.
   sw2.    ls-dyna responds with time and cycle numbers.
   sw3.    a restart file is written and ls-dyna continues calculations.
   sw4.    a plot state is written and ls-dyna continues calculations.
   lpri    toggle implicit lin. alg. solver output on/off
   nlpr    toggle implicit nonlinear solver output on/off
   iter    toggle implicit output to d3iter database on/off
   prof    output timing data to messag and continue
   conv    force implicit nonlinear convergence for current time step
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LSTC nor the authors assume any responsibility for *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. The user must verify his own    *
 * results.                                                   *
 * LSTC endeavors to make the LS-DYNA code as complete,       *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LSTC through your site focus.               *
 * Copyright (C) 1990-2016                                    *
 * by Livermore Software Technology Corp. (LSTC)              *
 * All rights reserved                                        *
 Beginning of keyword reader                                   04/04/24 12:32:40
 Memory required to process keyword     :      350314
I don't know what problems my file is having with the calculations.
