Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Difficulty in Meshing due to NURBS surfaces › Reply To: Difficulty in Meshing due to NURBS surfaces
rahul saini
Yes I have solved similar problem of corrugated sheets with corrugation angle only in one direction. but in this geometry I am using corrugation pattern in both dierctions (as in plate type heat exchanger  plate). Also the distance between plates is 3.63 mm. Amplitude of corrugation is 1.59mm. The dimensions of plates are 470x200mm.
