Ansys Learning Forum Forums Discuss Simulation General Mechanical Need help with moving heat source on uneven surface with apdl Reply To: Need help with moving heat source on uneven surface with apdl
Robin Lorenz
Thank you very much for your assistance.
Could a surface flux result in the same results as a Gaussian Laserprofile?
Or could it be possible if i mesh the target region as small and evenly as possible and target specific nodes with the code in order to reuse the other parts of the script? I was able to validate the results of the code in practice on a simple geometry via metallurgical analysis.
