Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need help with moving heat source on uneven surface with apdl › Reply To: Need help with moving heat source on uneven surface with apdl
April 3, 2024 at 5:46 pm
dlooman
I see the demo model has a thin uniform mesh so that the heat input can be quantified. I still think a surface flux (SF) makes more sense. An ambitious first step would be to just get a narrow uniform heat flux to move across the tip of the tooth using the method I showed.
