Ansys Learning Forum Forums Discuss Simulation Photonics app is crashing Reply To: app is crashing
Amrita Pati
Hi Ashish,
If you are using the project to script files, then I would like to add that it is still initial stages and still needs some improvements. Would you be able to share your script (paste here) so that I can test it myself? If it is a bug I need to reproduce it before I could file a bug report.
The purcell factor is the ratio of the emission of a dipole in a given set of conditions as opposed to the emission in a homogenous medium. So, you can either calculate it by taking a ratio of the results returned by the dipolepower and the sourcepower script commands. Or there is another equation which in terms of the quality facor and mode volume. You can find axact detaile here: Purcell factor of a microdisk.
Hi Hasfer,
Could you please create a new post so that the engineers working on the infrastructure side can look into it?
Amrita
