Ansys Learning Forum Forums Discuss Simulation General Mechanical Unable to see .rst files in Solver Files Directory Reply To: Unable to see .rst files in Solver Files Directory
Ram Gopisetti
Hi Luis,
If you talk about the explicit dynamics, the solutions are given in the  admodel_xx.adres files , on reading and writing the files into the system its currently blocked by an XML tag at backend and this might be changed in the newer versions,
Cheers, Ram
