Ansys Learning Forum Forums Discuss Simulation Fluids No friction at inlet Reply To: No friction at inlet
Yes, but if you plot the contour in Fluent (unless you used CFX) you can plot with node values on (smooth contour) or off (cell values) which highlights the mesh resolution on the velocity gradients.  1000m/s is fairly rapid!Â
