Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Mooney Rivlin Error › Reply To: Mooney Rivlin Error
Akshay Maniyar
Hi Harry,
Are you using the material from the Ansys database or do you have any test data for the material you want to use?  Also, what type of Analysis are you doing? As per the error message, it looks like you need some material property data which is not defined in your material definition.
Thanks,
Akshay Maniyar
