Ansys Learning Forum Forums Discuss Simulation Photonics Regarding box of monitors Reply To: Regarding box of monitors
Amrita Pati
Hi Prabha,
I found this figure in the appendix, so I don't see it mentioned that they are using a script to generate it. You can add a few lines of script to plot this from the "farfield" analysis group. Or you can just right-click on the farfield group-->Visualize-->farfield-->Ok (in the pop-up).
The plot is 3D, so you may rotate it to such that the x-y plane is normal to the screen:
Amrita
