Ansys Learning Forum › Forums › Discuss Simulation › Fluids › error message for Turbulent solution component in Fluent › Reply To: error message for Turbulent solution component in Fluent
Federico
Hello Jason,
it is difficult to say from this information alone. The error just says that the solution for the system called “Turbulent” failed.
Can you provide more details on the changes that you made from your Laminar setup to the Turbulent setup which may have caused this?
