Ansys Learning Forum Forums Discuss Simulation Fluids can’t writing showing warning”underdefined variable and unknown property” Reply To: can’t writing showing warning”underdefined variable and unknown property”
The write error is linked to the path - does that exist on the machine you're running on? The other errors are most likely linked to a lack of UDF.
Fluent set up files may contain the full path to files rather than the local path, this can cause problems with report files etc being written to odd places on computers.
