Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Help with Battery MSMD model › Reply To: Help with Battery MSMD model
Harsh Lakkalkatti
@Murari Iyengar, Thanks for your response.
I had one doubt about the UDF Diffusivity. In the photos that I've shared, the previous versions say "UDF Diffusivity in kg/m-s". How is this unit related to Electrical conductivity in 2023R1 version, which is in S/m? Aren't these completely different things with different units? I didn't understand how I can put values from previous versions in kg/m-s, and 2023R1 in S/m. Can you please give me some clarity in terms of units,definitions or conversion of the numbers (from kg/m-s to S/m if any).
Thank you so much for your time.
