Ansys Learning Forum Forums Discuss Simulation Fluids Species Velocity Outlet Reply To: Species Velocity Outlet
You set the volume fraction for the inlet, on the outlet Fluent ought to remove all of the phase at the rate you set. If you're seeing a diffusion effect turn it off in the species panel.Â
