Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unconverged solution for axisymmetric indentation › Reply To: Unconverged solution for axisymmetric indentation
Puhia Qalaj
Thank you for your response!
My model is very simplified, focusing only on linear elastic deformation. My objective doesn't involve plastic strain or fracture.
Regarding the axisymmetric conditions, in my SpaceClaim design, the y-axis is positioned at the left edge and it is around this edge that I want my rotation. I'm unsure if this placement in SpaceClaim affects the rotation for axisymmetry. Could you clarify whether the rotation is centered around the left edge? Additionally, my model design is in the x-y plane but I do not know if there are additional restrictions, such as restricting it to positive values on both axes.
Thank you for your help!
Best regards,
Puhia
