Ansys Learning Forum Forums Discuss Simulation General Mechanical Unconverged solution for axisymmetric indentation Reply To: Unconverged solution for axisymmetric indentation
Akshay Maniyar
Hi Puhia,
Thank you for the description. It looks like you modeled both the part as linear material. Are you expecting any plastic strain or fracture in bone material? You will need to create a proper material model to get the correct results.
Regarding the axisymmetric behavior, the Y-axis is considered as the axis of rotation and geometry should be in the XY plane.
Thanks,
Akshay Maniyar
