Ansys Learning Forum Forums Discuss Simulation Fluids material properties input Reply To: material properties input
Assuming you're using the solidification-melting model you need to set properties such that a single temperature can't have two values, ie density moves from solid to liquid over a very small, non zero, temperature change. Tha may require some care and piecewise linear over polynomial.Â
