Ansys Learning Forum Forums Discuss Simulation General Mechanical Slow down of a mechanical simulation after restarting Reply To: Slow down of a mechanical simulation after restarting
yu272
Hi Gary,
Thanks for the suggestion. You are right, my simulation has highly imbalanced contact problems. However, for the same setup, I also tried to run with 32 processors. The simulation will assign 28 processors instead, seems like it never use all the processors. I will try to optimize the region of contact and keep you updated.
Sincerely,
Eric
