Ansys Learning Forum Forums Discuss Simulation General Mechanical Unconverged solution for axisymmetric indentation Reply To: Unconverged solution for axisymmetric indentation
Puhia Qalaj
Thank you for your response. For the definition of both materials:
For the rectangle:
For the tip:
I took the time to watch the video you suggested and have been experimenting with different approaches, unfortunately without success so far. I'm at a point where I'm not sure which direction to take to achieve the desired result.
In addition, I need clarification on the axisymmetric aspect. At the moment, I'm at a dead end because I haven't found an option that lets me specify the axis of rotation for this symmetry. My intention is to use the face on the left as the central axis for the axisymmetry operation.
Thank you.
Puhia
