Ansys Learning Forum Forums Discuss Simulation Fluids Particle count in a room Reply To: Particle count in a room
You can use velocity bc's with a negative flow to remove air. Make sure there's a pressure boundary somewhere to prevent the solver from forming a vacuum or infinite pressure (you'll never balance the mass in & out).
DPM relies on the DPM boundary setting: is it Escape?
