Ansys Learning Forum Forums Discuss Simulation Fluids Dissolved Oxygen Simulation Reply To: Dissolved Oxygen Simulation
Phase transfer will depend on how you set up the mass transfer. If you're seeing divergence what is going on in the flow? Too high a mass transfer rate may cause problems, but that's mostly a case of checking the maths and reducing the time step.
