Ansys Learning Forum Forums Discuss Simulation General Mechanical Mooney Rivlin Error Reply To: Mooney Rivlin Error
Akshay Maniyar
Hi Harry,
Can you share more details about the issue? As per the image attached, it looks like the curve fitting is not giving proper coefficients for the Mooney-Rivlin model. Do you have test data for a given material? Did you try other hyperelastic material models? Please check the below video on curve fitting and see if it helps.
How to Perform Curve-fitting for Hyperelastic Material Models — Lesson 1 - ANSYS Innovation Courses
Thanks,
Akshay Maniyar
