Ansys Learning Forum Forums Discuss Simulation Fluids Specific heat UDF energy imbalance Reply To: Specific heat UDF energy imbalance
As in change phi from the GUI? Possible yes; easy, not so much. You're needing to promote values as parameters into Fluent or using Scheme & GUI coding; the former is in the UDF manual, the latter is in the other half of the customisation manual: I don't recommend either unless you're experienced and doing a lot of runs.
