Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error: Invalid face geometry was encountered › Reply To: Error: Invalid face geometry was encountered
Bharath JS
Hello mjmiddle,
Thankyou for your response.
Yes, I have converted it into solid in SC and then used that in mechanical. But still the issue persists.
Thankyou for the info on the meshing strategy, I will try and let you know. I am planning to make top and bottom plates to act as compression plates. I have heard that this works better than named selections. Nevertheless, I will try this method as well.
Is there any other way to import a lattice .stl file for compression analysis?
