Ansys Learning Forum Forums Discuss Simulation Photonics Transmission values are very low during s parameter extraction Reply To: Transmission values are very low during s parameter extraction
Guilin Sun
So the question is from FDTD to INTERCONNECT (ONA)? The forum should be one-question one-post.
Here is a simple reply. In INTERCONNECT you can use script to extract simulation results, and the component parameters you set.
result:
getresult: https://optics.ansys.com/hc/en-us/articles/360034409854-getresult-Script-command
getresultdata: https://optics.ansys.com/hc/en-us/articles/360034407714-getresultdata-Script-command
getnamed: https://optics.ansys.com/hc/en-us/articles/360034408574-getnamed-Script-command
you can use
?getresult("ONA_1")
to know all the results from ONA.
Please write a new post if you have other questions.
