Ansys Learning Forum › Forums › Discuss Simulation › Fluids › radiation › Reply To: radiation
kishan.konannavar
Hello
I understand that you are operating between  25 degree Celcius and 35 degree Celcius, but then why do you expect the temperature to be higher than 35? Is there another heat source?
Which solver did you use to get the steady state solution?
Thank you.
