Ansys Learning Forum › Forums › Discuss Simulation › Electronics › software jamming problem of Maxwell › Reply To: software jamming problem of Maxwell
April 1, 2024 at 4:22 pm
GLUO
The numbers you provided look good. Is TDM the only distribution type which is turned on? Do you see a heavy usage in your computer task manager while solving? Sometimes other issues like some feature is not support TDM will also cause this TDM solver aborted due to insufficient memory error. If you have tried solving with HPC disabled, you could check the memory usage in the solution profile for sigle task, and then estimate the total memory usage for HPC.
GL
