Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected during single particle deposition analysis Reply To: Divergence detected during single particle deposition analysis
Diego Fernando Garcia Gonzalez
Hi Rob, I bring new updates to the thread, show you the suggestions you recommended to me.
Below I show you a comparative image of the results obtained by increasing the mass of the particle while maintaining the density difference between the rigid body and the fluid. There's no significant difference, which gives me more options for analyzing a 3D model.
I've been able to carry out validations with the sedimentation of the circle, and I have had good results.
Answering your question about the flow field before divergence for the case of elliptical cylinder sedimentation, I show you the following images:
These are the results of the velocity field for different times, very close to each other before the divergence. I also include the report of the residuals, I'd like to know if u perceive what may be happening?
Thanks Rob.
