Ansys Learning Forum Forums Discuss Simulation Preprocessing TBPT IS NOT SUPPORTED FOR PLAS TABLE FOR MATERIAL 5 Reply To: TBPT IS NOT SUPPORTED FOR PLAS TABLE FOR MATERIAL 5
mrife
Hi Adeleine
TBPT defines XY data points for some material models defined by the TB command...which there are none in the APDL code shown.  Not all material models defined with TB use the TBPT command.  Looks like material with ID number 5 in the model is one of those. Â
